Destin-LX Linen Pin Hood Left Motor with Remote 24 Ft. Wide x 10 Ft. Projection Retractable Awning
VISIT STORE
- Beauty-Mark brand Destin-LX model motorized retractable awning with aluminum protective hood - Manual over-ride motor with remote control. Left motor when facing the awning - 24' wide x 10' projection or depth with adjustable pitch - Multi chamber arms with stainless steel cables - Structural steel and aluminum frame, powder coated in white - Fade, mildew, water resistant 100% solution dyed acrylic fabrics - 10 Sahara style valance with off-white trim - Fully assembled, ready to install and comes with the wall brackets - 5 year limited warranty - Product Depth: 120 - Product Width: 288 - Product Height: 10 - Product Weight: 219 - Material: Fabric - Minimum Mount Height: 96-in - Minimum Required Clearance: 10-in - Includes Fully assembled awning, product manual, rocker arm, wall mount brackets, and remote control Awntech Corp - DTL24-8-LPIN
Destin-LX Linen Pin Hood Left Motor with Remote 24 Ft. Wide x 10 Ft. Projection Retractable Awning Review
I've only had this Destin-LX Linen Pin Hood Left Motor with Remote 24 Ft. Wide x 10 Ft. Projection Retractable Awning for about two weeks. I suppose I'll have to play with it some more to get the feel for it. In the meantime, it satisfies my need for a awnings
